Question Radiator Installation Advice for Lian Li PC O 11 Dynamic
Oct 31, 2019
Hi,
In the Lian Li PC O 11 Dynamic enclosure I will collect a custom liquid-cooled system. What is the best double radiator installation in this case? I need your advice. Note: I will do vertical video card assembly.
Karadjgne
Herald
There is no 'best' as such. You'll need radiator area wattage enough to meet the needs of whatever you are cooling, cpu or gpu or both, ram, motherboard, whatever. Once that's met or even a little more, it's all the same thing. The only difference being the brands you choose, components you choose etc, and much of that is personal bias and preference.
