"RAID 0 generally is the best choice if you require high data transfer rates; in fact, it is possible to almost double throughput numbers by deploying a RAID 0 configuration. However, access times do not improve, and sometimes you will even see an increase in access time. Your everyday life with Windows won't be accelerated much by using a RAID 0 array, even if many people tend to believe that! We have proof for this statement in the form of benchmark numbers that compare the WD1500 Raptor with a two-drive RAID 0 setup that consists of two 7,200 RPM drives."
This basically says that loading games will be faster in Raid-0, but nothing else. In fact you may see a slight decrease in access time for basic computing.
Makes me wonder if I should upgrade my CPU's in both of my AMD64 comps and just split my raptors as boot drives, one in each. Right now I have a Caviar 160gig 7200rpm raid-0 setup in one and a Raptor 150gig 10K rpm Raid-0 in the other. In my bigger system I have extra storage in the form of a 10gig 5400rpm drive, and an 80gig 7200rpm drive. The chips are a mere Athlon 3000+ (bought the cheapest with upgrading to FX-60 in mind) and a 4200+X2, to be put in my cheaper system. I want two good systems, one for a friend to use when they come over and for lan parties (mATX), and then my power system for my own gaming (SLI option but not currently used). I'm going to be rearranging my systems here soon to optimize power in one of them, and eventually kick this 3000+ chip over to my HTPC I'm starting to build.
I'm still a little split what to do with my drives. Anyone else have some suggestions?
