Hello everyone!
So I built myself a PC with the old parts I had laying around for various purposes, I decided to use my old Kingston 120gb SSDs as drives but set them up in Raid0, problem is, it won't let me.
First of all the Hardware:
Its running off an Asrock Z68 Extreme3 Gen3, and yes, Sata mode is RAID. And as mentioned before, the system has 2 120gb Kingston SSDs.
After enabling raid mode, I went into the Raid utility with CTRL+I and wanted to set the raid, only thing is when I choose raid 0 it won't let me select the drives, its simply grayed out (hope you can see it in the pic)
When I switch to recovery the select disks option suddenly becomes available.
If I start without selecting the disks it simply gives me an error and only selects one drive as member, the other stays non-raid.
I've done this before on a different board and back then it went fine with selecting the disks, does anyone know where the problem is here?
PS: Heres a pic of the drives in the raid utility:
