There really doesn't seem to be a correct forum for this question, but here goes:
I've got a Supermicro X9DR3-F motherboard (which is EOL, so no support from SM) running Windows Server 2008 R2 with Raid1 and Raid10 arrays. I need to upgrade to Server 2012 R2 , but have had no luck with an "in place" upgrade. It hums along until the second reboot, then restores the original with "sorry". I've replaced my raid array with spares and successfully done a fresh install, so I'm pretty sure the MB isn't the issue.
The setuperr.log file shows a repeating sequence of four files that are having problems, each reporting two errors each time:
Plugin {0b23c863-4410-4153-8733-a60c9b1990fb}: LoadLibraryEx error (E:\$WINDOWS.~BT\Sources\ReplacementManifests\Microsoft-Windows-TextServicesFramework-Migration\IMJPMIG.DLL) gle=126
Plugin {0b23c863-4410-4153-8733-a60c9b1990fb}: LoadLibrary error (C:\Windows\system32\IMJPMIG.DLL) gle=0
These two lines repeat for four different DLL files (IMJPMIG.DLL,IMKRMIG.DLL,CHXMIG.DLL, TableTextServiceMig.dll), then the group of eight repeats several dozen times. Finally, the last entry is:
Plugin {ee036dc0-f9b7-4d2d-bb94-3dd3102c5804}: BRIDGEMIG: CBrgUnattend::CollectBridgeSettings failed: 0x1, 0
My 2008R2 raid driver is labeled xxWin7xx, which is the base the 2008R2 is apparently built. The clean install required Win8 drivers before it would even start. I haven't tried to install the Win8 drivers under 2008R2, since "driver updates" doesn't approve, although I might be able to override the refusal. Not sure if that might crash my current system, although I do have bare metal backups. I've read that the correct driver is built into 2012R2, so it's probably not the issue.
Microsoft hasn't been any help after three weeks of "looking at it".
The only other odd thing about my system is that the D: drive is disk0 while the C: drive is disk1, for historical reasons.
Any suggestions would be appreciated..
