I have an MSI Ne0-2 FIS2R motherboard, which has the onboard promise raid controller (30278). Originally I set up my system with two SATA hard disks in Raid 0 configuration and using Windows XP home. Everything worked fine for a while then one day I booted the machine and during the detection phase it showed the array was offline, so essentially I could not boot the machine. Using the in-built diagnostic I tried to find out what happened. It appeared that the promise controller no longer recognised one of the disks as part off the array. Reading through the promise support, I think that the reserved sector on one of the drives became corrupted. Unfortunately there seems to be no fix for this, so essentially you have to rebuild the array, loosing all the data in the process. I did this, and once again the system worked fine for a while and then the same problem occurred. I have now stopped using the drives in RAID configuration until I can understand why this is so unstable.
Is this a common issue in general, or particular to this mobo, raid controller etc.? The system was moderately over clocked, could this be part of the problem? Looking for enlightenment.
