Raid problems
tadroptopgirl
28
GA-990fxa-ud3 version 1.0
amd phenom 2 3.4ghs x4
xfx ati radeon 4650
4 western digital 1 tb each in raid 5 array
2 seagates 1 tb each
sata add on card for opitcal drives
Set up my raid. functional at first and boots up into windows 7 and i can see the array drive
but when i restart the system it is critical because i go down a drive. seems like it is e same drive which is in the 4:01 slot
i have made it two different times. i dont want it to keep doing this.
I can not use raid if it is going to be unstable, how do i fix this?
tadroptopgirl
28
Ya im using caviar black drives western digital says they are good for software raid
Not yet I checked the drives with the western digital utility and they say they are good also replaced the cables same problem
Similar threads
