Raidmax rgb fans
Feb 16, 2018
5
Hey guys, i'm new here. Just wanted to ask, since i got a couple new raidmax fans, can anyone tell me how to make them work, cuz i never had rgb fans before.
Doesn't look like that motherboard has any RGB headers.
You can buy a separate RGB controller. There are many different makers. Just make sure you do your research to make sure your fans are compatible with the controller.
http://www.coolermaster.com/cooling/cooling-rgb-accessories/rgb-led-controller/
First off, it’s ok to have a Raidmax fan, but just make sure to not get one of their psus. They’re awful. Secondly, there should be 2 cables, one for power, and one for the rgb led power. If your mobo doesn’t specify any sort of led port, that means it doesn’t support additional LEDs.
