R Rocius Reputable Mar 5, 2019 12 0 4,510 Nov 14, 2021 #1 Would mixing same Mhz from same manufactorer even same name rams, but different sizes work together,? for example: CORSAIR Vengeance LPX DDR4 3200MHz 32GB 2x16GB with CORSAIR Vengeance LPX DDR4 3200MHz 16GB 2x8GB Thank you for your answers
Solution S S sizzling Nov 14, 2021 Maybe, maybe not. Even mixing 2 exact same kits isn’t guaranteed to work See the odd man out here https://forums.tomshardware.com/faq...y-ram-and-xmp-profile-configurations.3398926/
S sizzling Titan Oct 18, 2006 27,224 3,268 112,240 Nov 14, 2021 Solution #3 Maybe, maybe not. Even mixing 2 exact same kits isn’t guaranteed to work See the odd man out here https://forums.tomshardware.com/faq...y-ram-and-xmp-profile-configurations.3398926/ Upvote 0 Downvote Solution
scout_03 Titan Ambassador Feb 18, 2010 30,587 324 107,640 Nov 14, 2021 #4 use cpu-z spd and check the jedec of both set of ram they should also use same voltages . Upvote 0 Downvote
