RAM Compatibility Issue - HP 6000 Pro Elite MT
Caligirl
I bought an old computer that has only 2 GB of DDR3 and I want to upgrade it to run the max of 16 GB.
I have on hand one 8 GB stick of HyperX Fury (1866MHz, PC3-14900CL10, 1.5V, non-edd) but when I try to use it in one of the two available slots the computer just beeps and won't POST. Details of the MB and preexisting RAM are below.
Can anyone tell me why this doesn't work? And what should I get instead? Thanks in advance!
According to Speccy, my motherboard is:
Manufacturer Hewlett-Packard
Model 3048h (XU1 PROCESSOR)
Chipset Vendor Intel
Chipset Model Q45/Q43
Chipset Revision 03
Southbridge Vendor Intel
Southbridge Model 82801JD (ICH10D)
Southbridge Revision 02
And the installed RAM is:
Memory
Type DDR3
Size 2048 MBytes
Channels # Single
DRAM Frequency 532.6 MHz
CAS# Latency (CL) 7 clocks
RAS# to CAS# Delay (tRCD) 7 clocks
RAS# Precharge (tRP) 7 clocks
Cycle Time (tRAS) 20 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 81 %
Total Physical 1.95 GB
Available Physical 361 MB
Total Virtual 3.89 GB
Available Virtual 1.07 GB
SPD
Number Of SPD Modules 2
Slot #1
Type DDR3
Size 1024 MBytes
Manufacturer Kingston
Max Bandwidth PC3-8500F (533 MHz)
Part Number KF680F-ELD
Serial Number 92183E7A
Week/year 14 / 10
Timing table
----------------- Freqcy------CL#----RAS# to CAS#---RAS# Precharge---tRAS--tRC----Volt
JEDEC #1----457.1 MHz------6.0--------------6----------------------6----------------18-----24----1.500 V
Slot #2
Type DDR3
Size 1024 MBytes
Serial Number 9118567A
Week/year 14 / 10
Timing table
JEDEC #2----533.3 MHz------7.0--------------7----------------------7----------------20-----27----1.500 V
JEDEC #3----533.3 MHz------8.0--------------7----------------------7----------------20-----27----1.500 V
