G
Guest
Guest
Hi,
I have a PC which I want to increase the memory of, I know the motherboard will let me install more (at least 4gb).
It's running Vista 32bit so i'm assuming that in a normal situation I could only increase to about 3gb RAM as the OS would only 'see' that amount. Does this mean that if I install more than 3gb other software (other than the OS) would not be able to access more than 3gb RAM either?
A complication is that i'm running VirtualBox on it (hence the need for more RAM), my VM is running OpenSUSE 11.2 64bit, so would the VM's OS be able to make use of the extra memory even if Windows can't?
Or would it just be easier to upgrade my Windows to 64bit?
On a related note if I upgrade my OS does it retain the installed programs etc.?
Many thanks,
Guy
Many thanks,
Guy
