I recently installed a new CPU heatsink/fan on my Q9550, the Coolermaster Geminii S.
The problem is that the heatspeader fin on my OCZ ram is touching the side of the CPU fan because it is too tall.
take a look at this picture and you will know what i mean
http://www.ocztechnology.com/products/memory/ocz_ddr2_pc2_6400_reaper_hpc_4gb_edition
and the CPU cooler
http://www.coolermaster-usa.com/product.php?category_id=1623&product_id=2729
Its actually more than touching, since the ram's heat fin is maybe bending around 3mm outward because the 120mm fan is blocking it.
So since i'm really paranoid i switched out the ram stick that is touching it and put in a Value Samsung 2gig stick in its place. But for overclocking reasons, i want to get rid of it.
if i put back the OCZ ram in is the heatfin going to melt the side of my fan or anything or going to prose any problem, i dont think that the 3mm bending is a big deal, i just dont want my cpu fan to melt from contact with the heat fin
and the CPU cooler
