Hi
ive been having problems with pc freezing which requires hard reboot whilst playing a cpu hungry game (left 4 dead 2).
this has happened quite a lot and its very frustrating. i have replaced power supply (now have 550w), cleaned parts and re-applied thermal paste (cpu temp now around 59c in game) and checked ram sticks are in place correctly.
the freezing continues. now i should make sure my bios settings are correct for the ram but this has got me confused!
please could somebody in the know take a look at my specs below and advise me if my bios is incorrect?
many thanks.
my gpu is ati hd4670 by the way so its up to the job.
i checked with bios and it reports memory speed is 333 mhz.
CPU Properties:
CPU Type AMD Athlon 64 3500+
CPU Alias Venice S939
CPU Stepping DH-E6
CPUID CPU Name AMD Athlon(tm) 64 Processor 3400+
CPUID Revision 00020FF2h
CPU Speed:
CPU Clock 2232.28 MHz
CPU Multiplier 11.0x
CPU FSB 202.93 MHz (original: 200 MHz)
Memory Bus 159.45 MHz
CPU Cache:
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 512 KB (On-Die, ECC, Full-Speed)
Motherboard Properties:
Motherboard ID 63-0100-000001-00101111-041806-ATHLON64$0AAAA000_BIOS DATE: 04/18/06 17:38:25 VER: 08.00.12
Motherboard Name Unknown
Chipset Properties:
Motherboard Chipset ATI Radeon Xpress 200, AMD Hammer
Memory Timings 2.5-3-3-7 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memory Modules:
DIMM1: Infineon 64D64320HU5C 12 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-2-2-6 @ 133 MHz)
DIMM2: Infineon 64D64320HU5C 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-2-2-6 @ 133 MHz)
DIMM3: Kingston K 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
DIMM4 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-2-2-6 @ 133 MHz)
many thanks.
CPU Properties:
CPU Stepping DH-E6
CPU Speed:
CPU Cache:
Chipset Properties:
SPD Memory Modules:
