RAM issues help
Neo_136
Commendable
Oct 9, 2016
Hello, I have a question about RAM i have a mb that supports 1600 mhz ram and 1333mhz ram the cpu that i have also can support those two mhz. The problem is i dont know how will they work if i put 1 stick of 1600 mhz 4 gig and 1 stick 1333mhz gig. Tnx for your replyes. Peace
If you have them - give them a try, not going to hurt anything, they will either play or they won't. If they don't want to, can often make timing/voltage adjustments to get them to play either at 1333 or possibly 1600 😉
