Question Ram not running at 1600mhz
Aug 14, 2020
5
I have maximus V gene, and I had 16 gb d DDR3 1600 Mhz RAM.
The MB's guide said that it could have 32 so I got and extra pair of 16GB DDR3 1600 Mhz.
The thing is now when I boot my PC and set to 1600 in bios it constsntly crashed (blue screen error). I thought those ram could be damage, but then also I thought maybe I was sold 1333mhz ram so i adjusted it to 1333mhz at the bios and my computer rans perfectly, haven't had a single crash since then.
Checked the model of the ram and did an online search and they are indeed 1600 Mhz RAM, so there lies mi issue, I can't get them to run at 1600mhz. Dunno if my motheboard doesn't support 32gb at 1600 (in the manual doesn't say I can't) or maybe im still missing a config in the Bios.
The mainbord doesn't hace a preconfig xmp profile, but I have it overclocked.
Ziadul87
490
48
740
21
I'm guessing you bought the RAM sticks separately. All types of problems can occur if they didn't come paired straight from the manufacturer.
