Question Ram not running at 3200mhz?
Adde21 30
17
So I recently bought ram that is supposed to be able to run at 3200mhz with 32gb. So I enable X.M.P. in bios, but the highest setting is 2400mzh, and when I check the speed in cpu-z it also says 2400mzh (1198 x 2). I also tried setting the right voltage manually (and the clock speeds that are on the ram sticks) yet it still only runs at 2400mzh. What do I do?
Specs:
Intel i-7 7700k
Rtx 2070
Motherboard is MSI H270M Bazooka
Ram is as mentioned Corsair vengeance 32gb 3200mzh
Your motherboard only supports a max speed of 2400mhz.
Source: https://www.msi.com/Motherboard/H270M-BAZOOKA/Specification
