Hi, first time posting here. I recently bought an additional Corsair Vengeance kit 2x8gb 3200mhz to add to my Corsair Vengeance kit 2x4gb 3200mhz, after installing both of them, they work great, but not at 3200mhz as expected. I know that my CPU Intel I5-6500 doesn't support more than 2133mhz but the motherboard does, it's a GA-Z170X-Gaming 3 (rev. 1.1).
I haven't tried the XMP profile because I'm a little scared (for not knowing) of doing something wrong (and I'm not in a position to lose my PC). The same with setting the voltages manually.
After checking the BIOS, also found that the timings and voltages are settled lower than they should run. Can this be harmful if they keep working in lower settings? (Check images below)
Specs:
CPU: Intel Core i5-6500 3.20Ghz
Mother: GA-Z170X-Gaming 3 (rev. 1.1) BIOS v.F4
RAM: 1kit Corsair Vengeance 2x4gb 3200Mhz - 1kit Corsair Vengeance 2x8gb 3200Mhz (Both should run at the same timings and voltage according to the info in the Rams)
GPU: GeForce GTX 1060 6gb
Let me know if you need any other information. Thanks in advance!
Specs:
