RAM not running at advertised speed
Do_The_Panic
21
Hey everyone I'm currently having trouble running my G. Skill 8Gb 1600 Mhz RAM. My rig runs it at 1333 Mhz. The SPD info in the BIOS recognizes that it has possibility to run at 1600 Mhz. Whenever I try to increase it the computer restarts and says that my Overclocking attempt has failed. My CPU is a i7 2600. I think that it might be the CPU that is the reason why it is bottlenecking and won't run at the 1600 Mhz I desire. I think I might somehow have to disable the Integrated Memory Controller on the CPU but I'm not sure how to do that and if that is even the problem here are the links of components. Also my Asus P8H77-V LGA 1155 mobo can run 1600 Mhz up to over 2000 Mhz so I know the mobo can run this ram
processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131834
Thanks for help you guys! I really appreciate it!
