Ok, so this is my build - https://pcpartpicker.com/list/wCLxV6
Ram- (2x8gb) Corsair Vengeance Pro RGB 3200mhz
Motherboard- MSI Gaming Pro Carbon x370 (AM4)
CPU- AMD Ryzen 5 1600
Everything works perfectly fine on the PC except my ram. It does not run at the base speed of 3200mhz and instead Corsair Link says that it is running at around 1000mhz (sometimes it drops to 900mhz) and on Corsair iCue it runs in the low 900mhz. I tried to enable XMP in the bios, but it will result in not liking it and I would have to reset the CMOS, I can also manually set it to 3200mhz, but that would also result in me needing to rest it. Does anyone know why my ram does not like to run at the correct DRAM frequency?
