Ram not running at his normal speed
iByakko
24
Hi first my system:
MOBO ASUS MAXIMUS RANGER 8
CPU: i7 6700k
Ram: Corsair Vengance LPX 2 x8 (16gb) 3200mhz
PSU: Thermaltake 1200w Smart
So my problem is that the RAM's are not running at 3200 the preset on BIOS says 2133mhz but the CPU-Z says they are running at 1070mhz... I tried using XMP but shows "overcloking failured"
I read that some times the XMP is not configurated well so its better a manual config if anyone can guide me it would be perfect to adjust them to 3200.. something like: GO TO ADVANCE>XXX>XX and do XX please help me 🙁
PD: To make it better it says "SINGLE CHANNEL" whats the config for dual channel?cuz I have them at A1 A2
Dont know how to OC the cpu... and a person on a forum write that the voltage used by XMP says 1355 but it the number that appear on the ram voltage its 1330 or 1340 and u have to change that and the agent system ram voltage but I tried to put 1355 and wont let me 1340 1360 no 1355... also about the single channel thing whats the config a1 b1?
PD: I wont update my BIOS .. Im afraid something can go wrong and I lose the mother... no thanks Ill try any other option but no that one
If I try 1.36 and it doesnt work can blows the ram? also the the person that write about the voltage says that I need to rise voltage of the agent but I dont know whats that Oo
Well now Im dual channel but I dnt know if I should touch anymore.. 2 times and 1 I had to clear cmos and the other the post told me "overclocking failured" :X not trying this about rising the voltage thanks anyway.... it supose 1070 on CPU Z means 2133 so I better leave it that way for now
