Hello, I've only recently realized my RAM's running at x6.66 (1333mhz) instead of x8.00 (1600mhz). This is not that much of a big deal, but since I'm mainly a video editor I'd prefer having it run at full speed.
I'm OC'ing my cpu by increasing bus frequency (running 215), it gives 4.3mhz but this also puts my RAM at 1433mhz and going up to 1600 that way will leave all components OC'd beyond comprehension of my system. Using manual preset and setting it to 1600 is the logical thing here, only whenever I as much as touch that setting I won't even get into windows. BIOS then tells me the last working clock speeds and asks me to return to those.
I'm running manual voltages set on default except on the cpu, also tried increasing the RAM voltage when doing 1600mhz but that didn't do the trick.
As far as I realize CPU-z shows half the supposed speed, so logically 716.5 means 1433MHz. Also slot 1 is identical to slot 2, and slot 3 is identical to slot 4. They're both corsair vengeance with same timings etc, only difference is their age and heatspreaders. I figured these 2 types of RAM would work fine together.
https://www.dropbox.com/s/4rmgi3ofj1hy2ty/1.png?dl=0
https://www.dropbox.com/s/ngyybsdcpzjtn3t/2.png?dl=0
https://www.dropbox.com/s/sz7rmpohk1o4f6n/3.png?dl=0
