Question RAM or CPU problem?
Nov 30, 2020
Just bought 2 new sticks of memory same brand as before, but after i bought them i realised that they have different voltage and frequenzy.
I installed the 2 sticks anyway.
It seemed to run smoothly until i started editing and the computer got some heavy load. then the pc completly froze.
After some experimenting with placement of the sticks and tweaking in software - i found out that the problem only occur when i have set the CPU setting in ryzen master to "creator mode" if the settings is set to "game mode" the computer does not freeze.
I dont understand what the problem is, and i need some help to figure it out.
Is there really any difference in performance between "creator mode" and "game mode" ?
Legacy compatibility mode in on in game mode and off in creator.
Memory accsess mode is Local in Game mode and in Creator its distributed.
Threadripper 1950x
Gtx 1080 ti
2x16 Hyper fury x 2666
2x16 hyper fury x 3200
