Hi,
I got a Core2 dup E6600 on an ASUS P5B-Deluxe
I also have 2 sticks of 1GB ddr2 667 (Kingston KVR667D2N5)
When I overclock my cpu and set the bus to 333 (1333Mhz), and set the memory at 1:1 (so 666Mhz), the system won't boot, black screen. However with OCZ memory modules it works perfect, so I started to suspect the Kingston memory.
After a lot of testing, I managed to make the system work with those Kingston stick... by over-volting the DDR to 2.1V even they are working at 666Mhz (which is their spec).
The system seems stable, I did some prime95 torture tests successfully... now I'm wondering if it is safe to run those Kingston DDR at 2.1V as the memory chips get pretty hot? I don't have any memory heatsink on hand
Also, any idea why I need to increase the voltage of the DDR when they're not overclocked?
Thanks,
David.
Thanks,
David.
