Hi everyone,
a while ago a posted the system I bought. I went with the suggestion and changed the RAM to F5-6000J3040G32GX2-TZ5N. It should arrive somewhen this week.
I had a chat with a colleague who wants to buy a similar system and did some research, and he pointed out a few points I am wonder if they are true. Can you please help me out with a fact check.
I would really appreicate a quick answer, so I can react accordingly
- 64 GB RAM might not fit with the Noctua FAN (or raise the need to install it differently?)
- The 64 GB G.SKILL RAM do not run without error as (the mainboard?) BIOS does not work yet properly with DDR5, corsair dominator would be a more stable pick
- I checked the compatability list, the mainboard is listed on the G.SKILL site, but the RAM are not listed on the Mainboard site. Strangley enough the list the exact same version but with XMP instead of EXPO as supported. But EXPO would make more sense with this setup?
View: https://imgur.com/a/2mLx3Aa
- 850 Watt power supply is at the absolute limit with a RTX 4090 and a 1000 Watt powre supply would be the better and also more future proof pick.
- AMD Ryzen 7 7800X3D Box AM5 (4,2GHz) 100-100000910WOF
- NOCTUA Noctua NH-D15 Computer Kühlkomponente Prozessor Kühler 14 cm
- BE QUIET! Dark Base Pro 901 (schwarz)
- IGABYTE Gigabyte GA-B650E-AORUS MASTER (AM5) (D)
- THERMAL GRIZZLY Thermal Grizzly Kryonaut Wärmeleitpaste - 1 Gramm
- G SKILL DIMM 64 GB DDR5-6000 (2x 32 GB) Dual-Kit (schwarz, F5-6000J3040G32GX2-TZ5N, Trident Z NEO, AMD EXPO)
- BE QUIET! be quiet! Netzteil Straight Power 12 850W 80+ Platinum Mod.
