Ram problem: Crucial 8GB KIT DDR3 1600MHz
okoice
27
So after putting those 2 rams in my ram slots the computer wont launch the boot stuff. I start computer and it does nothing just black screen.
When i put back my 2 older rams then it work without problem.
Here is my systém info:
Processor: AMD Phenom(tm) II X6 1055T Processor (6 CPUs), ~2.8GHz
Card name: AMD Radeon HD 6800 Series
Operating System: Windows 7 Home Premium 64-bit
On crucial when i ran scanner it showed me that i can put those in my systém so i bought them and after trying them out they didnt worked, plz help.
Crucial 8GB KIT DDR3 1600MHz CL8 Ballistix Tactical LP
It should when my older rams were also ddr3 and on crucial site it said that those are compatible.
Here is my board
Hi
Assuming you fed the motherboard model into crucial's system and it recommended them, then there is ( or used to be ) a money back guarantee
I would reset the CMOS using motherboard jumper ( follow user guide instructions re removing mains power etc)
Then remove both old ram, insert 1 new ram in correct slot again read user guide
See what happens .
If it works insert second ram again in correct slot
Then check bios setting correct after reset eg date time etc
Regards
Mike barnes
First i tried 2 rams from crucial it didnt worked i even switched positions and nothin.
Second i tried 2 of my older rams it worked.
Third im too scared that i break something. But i will try the 1 tomorrow and post reply. And if it wont work then what do i do next just in case. I really want to have 2x4 gb rams otherwise i lost my money. Currently i have on my old rams thats 2x2 from kingstone.
