RAM problem help
spider40
70
I have 2 rams on my pc. One is the kingston value ram 4 GB and the other one is Corsair vengeance 4 GB ram. Can my computer use the faster ram to operate instead of the slower ram in any ways
Unlocked CPU can be overclocked well beyond the stock speed... But regular (locked) CPUs can only be overclocked slightly... and it would take very conservative OC'ing to speed-up 1333 mhz RAM up to 1600Mhz.
I can OC my AMD locked Athlon from 3.0 GHz to around 3.3 or less and that alone can speed up my 1333MHz RAM to 1600+Mhz.. so it doesn't take much overclocking.
About locked/unlocked CPus
http://www.tomshardware.com/forum/317950-28-what-means-2600k
they are not over clocked. The Kingston rams speed is 1333mhz and the corsair's speed is 1600mhz
INTEL DH55TC
MY PC SPECS
Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz 7.0
Memory (RAM) 8.00 GB
Graphics NVIDIA GeForce GTX 650 Ti
Gaming graphics 4096 MB Total available graphics memory
how to enter the bios? I am a newbie on this stuff. So please tell me. what MHZ should i set. 16000 MHZ or higher?
I tried that thing but when i went to the memory configuration tab, i pressed enter. There was nothing to set the ram speed. Below the memory configuration tab, there were the speeds of ram. I was not able to go there, I was not able to access it. Please Help!
Prebuilt computers are brand name (Dell, HP, Acer, etc)... they usually have the BIOS locked, settings are either hidden or gayed out and inaccessible... So there's not much you can configure.
Overclocking the CPU can also overclock the RAM... see if overclocking the CPU is possible and if so, overclock it just enough so the RAM goes from 1333Mhz to 1600Mhz or around that.
how to re-flash the bios? Please help
I have an Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz processor. I have heard that the cpu's ending with I and K can be overclocked. Rest of the cpus cant.
