A Aaron Evans Reputable Jun 12, 2015 3 0 4,510 Jun 12, 2015 #1 So i have not been able to even boot up mc pc due to a problem with the ram im not sure whats wrong ill post a link to the picture below can sone help ? Thanks http://imgur.com/9JGSiNt
Vic 40 Titan Oct 22, 2013 20,976 1,024 88,990 Jun 12, 2015 #2 Which motherboard and cpu? Upvote 0 Downvote
A Aaron Evans Reputable Jun 12, 2015 3 0 4,510 Jun 15, 2015 #3 Its an old askrock ine and the cpu is amd im not sure which one as i cant boot up the pc and i didnt build it Upvote 0 Downvote
madmatt30 Titan Ambassador Jan 1, 2013 24,571 649 91,240 Jun 15, 2015 #4 Can you boot to bios even ?? Keep jabbing delete as its booting. Upvote 0 Downvote
A Aaron Evans Reputable Jun 12, 2015 3 0 4,510 Jun 15, 2015 #5 Nope just crashes my mointor wont even turn on anymore :/ Upvote 0 Downvote
Vic 40 Titan Oct 22, 2013 20,976 1,024 88,990 Jun 16, 2015 #6 For which motherboard could you look at the pcb,it should show which motherboard somewhere. Why do you think it's the ram anyway? Upvote 0 Downvote
M mattme00 Reputable May 26, 2015 36 0 4,540 Jun 16, 2015 #7 Do you have a diagnostics card to find the problem, or are you certain it is definitely the ram? Upvote 0 Downvote
