[SOLVED] RAM problems
FGnontechie
I have an Asus Prime X570-P motherboard with a Ryzen 7 3700x 8-core CPU. It has 16 GB Corsair Vengeance DDR4 RAM (2 x 8GB) installed in slots A2 & B2 as per the installation guide. The GPU is an NVIDIA Quadro k2200 but that should not make any difference to the problem I have.
The current installed BIOS is 0604 (as delivered) but there are later ones. I do not "over clock" or any other tweaks for game playing as the PC is used mainly for Photo & Video editing. Before I do something I will regret (I am not a techie expert and most sites say upgrading BIOS is risky and not generally needed), I would like some advice why the available RAM is only showing ~8GB.
The BIOS is detecting both RAM modules at the correct size and position. I have done as much "research" on this issue as I can and have checked that there is no set RAM limit. The OS system is Win 10 Pro.
I have considered buying another 2 RAM modules (the exact spec is still available) and putting it into the other two slots but I am not sure if that is throwing money away.
I built the PC in January this year but various issues (not least CV19) have really prevented me investigating this problem.
All help will be appreciated.
Reactions: egda23
Updating BIOS with newer Asus boards is easy, just follow directions in manual. (I recommend the USB flash method - remember to rename the file)
Thanks for these comments. I had wondered about updating the BIOS as the one I have is several updates behind and I notice that one update does mention improved DIMM handling. I will give that a try.
