As you can see from the title
This is a Noob Question, I have a 2400mhz ram installed on a h410m board, I turned on the xmp and made it run at 2666mhz, the thing is I only have 1 8gb stick of ram and my motherboard has 2 dimm slot, if I populate the other dimm slot with another stick, should I get a 2400mhz and make it run at 2666mhz via xmp? or shoud I go for 2666mhz stick instead? will it work together with my 2400?
Full Spec
i5 10400f
msi h410m pro vh
rx 580
hyperx 2400mhz ram 8gb
120gb sdd
1tb hdd
seasonic s12ii 620w 80+ bronze
Full Spec
i5 10400f
msi h410m pro vh
rx 580
120gb sdd
1tb hdd
