Question RAM running on 1067MHz with dual-channel set higher in BIOS (3200 MHz and 3600 MHz)
adyxoni
Commendable
Nov 28, 2020
15
My memory is running on 1067 (checked by running cmd command "wmic memorychip get speed"). I've tried the usual solution which is enabling XMP (which is in my case A-XMP) and tried switching the dual-channel cards between each other, however the PC can't boot then (I'm assuming the motherboard needs it like this due to different ram card speeds).
Why is my RAM running at 1067MHz when in BIOS I've set it to 2667 MHz?
PC SPECS:
Ryzen 5 1600
Motherboard MSI B350
RipJaws 8GB 3200MHz DDR4
RipJaws 8GB 3600MHz DDR4
GeForce GTX 1060 6GB
My PC crashed multiple times after playing VALORANT while Chrome and Discord were open at the same time , so could this be the issue to it?
PC SPECS:
Ryzen 5 1600
What does task manager/perf/memory show for ram speed?
