Ram running on 2000 mhz, even though bios xmp setting is set at 3000 mhz.
May 1, 2018
I just added 2x4 gb of 3000mhz ram on top of the 2x4 gb 2800mhz ram i already had in my system. My computer was running smoothly at 2800mhz with the correct xmp profile. After I installed the second set of ram, my bios only shows the new xmp profile set at 3000mhz. When i run cpu-z however it shows my DRAM freq is 931.1 mhz instead of the expected 1400 or 1500 mhz (either the the lower speed or the higher according to the xmp.)
Any ideas around on how to set the freq. of both sets of ram at either 2800 or 3000 mhz?
I have an asus b350 prime plus, ryzen5 1600, trident z f4-2800c15d-8tzb and trident z f4-3000c15d-8gtzb.
chipset
Northbridge AMD Ryzen SOC rev. 00
Southbridge AMD B350 rev. 51
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR4
Memory Size 16 GBytes
Channels Dual
Memory Frequency 931.1 MHz (3:28)
CAS# latency (CL) 13.0
RAS# to CAS# delay (tRCD) 13
RAS# Precharge (tRP) 13
Cycle Time (tRAS) 30
Bank Cycle Time (tRC) 44
Command Rate (CR) 2T
Uncore Frequency 931.4 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR4
Module format UDIMM
Manufacturer (ID) G.Skill (7F7F7F7FCD000000000000)
Size 4096 MBytes
Max bandwidth DDR4-2132 (1066 MHz)
Part number F4-3000C15-4GTZB
Nominal Voltage 1.20 Volts
EPP no
XMP yes
XMP revision 2.0
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 9.0-9-9-22-31 @ 666 MHz
JEDEC #2 11.0-11-11-27-38 @ 814 MHz
JEDEC #3 12.0-12-12-29-42 @ 888 MHz
JEDEC #4 13.0-13-13-31-45 @ 962 MHz
JEDEC #5 14.0-14-14-34-49 @ 1037 MHz
JEDEC #6 15.0-15-15-35-50 @ 1066 MHz
JEDEC #7 16.0-15-15-35-50 @ 1066 MHz
JEDEC #8 18.0-15-15-35-50 @ 1066 MHz
JEDEC #9 19.0-15-15-35-50 @ 1066 MHz
XMP profile XMP-3002
Specification DDR4-3002
Voltage level 1.350 Volts
Min Cycle time 0.666 ns (1501 MHz)
Max CL 15.0
Min tRP 10.59 ns
Min tRCD 10.59 ns
Min tRAS 23.16 ns
Min tRC 33.78 ns
Min tRRD 3.75 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 15.0-16-16-35-51-n.a @ 1501 MHz (1.350 Volts)
DIMM # 2
SMBus address 0x51
Memory type DDR4
Module format UDIMM
Size 4096 MBytes
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 15.0
Min tRP 10.59 ns
Min tRCD 10.59 ns
Min tRAS 23.16 ns
Min tRC 33.78 ns
Min tRRD 3.75 ns
DIMM # 3
SMBus address 0x52
Memory type DDR4
Module format UDIMM
Size 4096 MBytes
Part number F4-2800C15-4GTZB
EPP no
XMP yes
XMP revision 2.0
AMP no
XMP profile XMP-2800
Specification DDR4-2800
Voltage level 1.250 Volts
Min Cycle time 0.714 ns (1400 MHz)
Max CL 15.0
Min tRP 11.33 ns
Min tRCD 11.33 ns
Min tRAS 24.83 ns
Min tRC 36.33 ns
Min tRRD 3.43 ns
XMP #1 15.0-16-16-35-51-n.a @ 1400 MHz (1.250 Volts)
DIMM # 4
SMBus address 0x53
Memory type DDR4
Module format UDIMM
Size 4096 MBytes
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 15.0
Min tRP 11.33 ns
Min tRCD 11.33 ns
Min tRAS 24.83 ns
Min tRC 36.33 ns
Min tRRD 3.43 ns
