[SOLVED] Ram sockets faulty after applying thermal paste to CPU
Aug 13, 2020
19
Hello,
So i applied new thermal paste on my CPU. and i put so much of thermal paste and when i try to clean the TP(thermal paste) i saw the socket have a little ammount of TP so i try to clean it
I did <Mod Edit> up a bit and bent 2-3 of the connectors from the CPU socket as i was cleaning my PC. Tried to fix them as good as possible. When i was done installing the cooler and plugged in my PC, it gave me the rapid BIOS beeping indicating something is wrong with my RAM.
After some testing now, turns out the RAM slots the two closest to the CPU socket, are causing the problems.
and the other slot are good and run smothly
and now have some of TP on the socket in edge of the socket how i clean them ??
My setup is
Intel i7-8700k,
Adata 2x8GB Dual Channel 3200
Aorus z370 ultra gaming 2.0
Thanks for reading.
Thermal paste ys meant to be applied sparingly as it's there to fill the tiniest of voids.
Use isopropyl alcohol 99% and a lint free cloth to very carefully remove the excess and an artist brush in difficult to get at places.
Hope you managed to straighten the CPU pims as that can cause your RAM issue.
Reactions: Mohjolan
yes i do exactly what you say and now its all work fine now thx for help meant alot for me
but there is one problem my water cooling when i put the water cooling down its not working and when i put it up the case it work fine for 10 min then read errorr
