Ram speed for Ryzen ?
RagingRabbits
160
Right now I am on a very very tight budget and can only afford maximum of 8gb 2666 mhz ram and I plan on upgrading in a few months by adding in the same stick of ram .The problem is that this 8gb 2666mhz Kingston ram is a little hard to find in my local computer stores .So i was wondering if i should get a 8gb 2400mhz ram a they are much more easier to find .
My system : Ryzen 5 1600
GPU : R9 380
Also I am aware that Ryzen works better with higher ram speeds but right now i really cannot afford the 3000mhz or 3200mhz ram
So is 2400mhz sufficient for Ryzen ?
Yes the 1600 is already purchased and the R9 380 is my existing GPU I live in Malaysia thanks for your help again vapour :)
same model may work, but not guaranteed, different batch may have slightly different timing... However, you can always sell and buy 2x8 later, ram price is only going up... Or if the shop has good return policy, worth trying. Geil is OK, not as good as G.Skill/Corsair etc., but for 2666 should be fine. checked some newegg reviews, that ram model seems fine.
The website has this:
14 days easy return
• Lazada guarantees that all purchased products are genuine, brand new and not defective.
• In case the product you received does not meet our commitment as stated above, you will have 14 days to return products.
• Lazada will refund the paid price of the returned item if it meets our Return Terms and Conditions.
• For more detail visit our FAQ
So you can try next time I guess.
