[SOLVED] Ram speed lower than it should be
With many motherboards sometimes they come at default low ddr4 speeds,2133. You can safely increase it to the correct level, however i don't think you're running them in dual channel mode, make sure they're in the correct slots, depending on your motherboard (check its manual it will say there)
Jul 8, 2018
16
