D Dagleesin Oct 12, 2019 6 0 10 Oct 12, 2019 #1 Hello i have aoru pro mobo and corsair 2x8 gb ram 3200mhz but my system running them at 2133 i change xmp profile but nothing changed... The other options are in auto mode... Plz helppp
Solution Phaaze88 Oct 13, 2019 https://pcpartpicker.com/products/motherboard/#m=18 You didn't specify WHICH Aorus Pro motherboard, but all the models from this list support memory overclocking/XMP/DOCP, etc. Also, you're not confusing Dual Data Rate, are you? 3200mhz/2 = 1600mhz.
Phaaze88 Titan Ambassador Dec 30, 2016 21,128 5,548 104,690 Oct 12, 2019 #2 Did you put the sticks in the wrong slots? Make and model of the motherboard? Upvote 0 Downvote
D Dagleesin Oct 12, 2019 6 0 10 Oct 13, 2019 #3 Gigabyte aorus pro i tested at 1-3 and 2-4 slots but nothing happens also i tested to 1 and 2 and my pc doesnt boot Upvote 0 Downvote
Phaaze88 Titan Ambassador Dec 30, 2016 21,128 5,548 104,690 Oct 13, 2019 #4 Manually input the frequency and primary timings. Then check with Cpu-Z on the Memory and Spd tabs. Upvote 0 Downvote
D Dagleesin Oct 12, 2019 6 0 10 Oct 13, 2019 #5 Phaaze88 said: Manually input the frequency and primary timings. Then check with Cpu-Z on the Memory and Spd tabs. Click to expand... I think my mobo doesnt supports this ram thats why.. Upvote 0 Downvote
Phaaze88 Titan Ambassador Dec 30, 2016 21,128 5,548 104,690 Oct 13, 2019 Solution #6 https://pcpartpicker.com/products/motherboard/#m=18 You didn't specify WHICH Aorus Pro motherboard, but all the models from this list support memory overclocking/XMP/DOCP, etc. Also, you're not confusing Dual Data Rate, are you? 3200mhz/2 = 1600mhz. Upvote 0 Downvote Solution
