Ram Speed stuck on 2133 on Msi B350 Tomahawk Motherboard
Flins
I've build my first PC couple days ago with Msi B350 Tomahawk, Ryzen 5 1600, Corsair Vengeance 3000mhz and Gtx 1070. Everything works fine, but my Ram speed is on 2133. I updated the bios on latest version but i cant get it to 2933. Whatever i try it's struggling to boot and after a minute or so when it finally boots it automatically sets the ram speed on 2133 again.
If you know how to fix it would be great. Thank you.
So i changed DRAM Frequency at 2667 while setting voltage on 1.35 but not touching timing and it booted but above that it does the same thing (2800 and 2933 Mhz). Is there a chance that for more speed it needs CPU OC aswell or something like that?
Yeah but i just couldn't find the correct timing for 2800 nor for 2933 Mhz. Been looking for it on forums and checked on Corsair's site and it says there that timing is 15-17-17-35 but that is for exactly 3000mhz,but on DRAM Frequency there is no 3000... There's 2933 and 3200 after that so couldn't find the right one... and i updated BIOS 2-3 days ago when i build pc and downloaded latest update from MSI's site
Anyways thank you for help atleast got it on 2667. Hopefully MSI will take care of it.
