Hi,
I'm planning on switching to AMD Ryzen from Intel but I'm a little confused about this RAM situation.
I need a new desktop for a software that needs high processing power with as many cores as possible and doesn't depend on the speed of RAM and definitely doesn't care much for the GPU.
So I thought i'll go with a Ryzen 7 2700x and use my already existing GPU nvidia 630 GT and use 2 DIMMs of 8 GB each.
Before we get into the RAM situation I wanna specify that I do not intend on overclocking this PC at all. I need this to last me as long as possible (at least 6 years) and I live in a hot climate so heat can totally be an issue and I don't wanna get any advanced cooling, i'll just use the stock CPU cooler.
As I was reading up I learnt that the speed of your RAM affects the speed of your CPU. Ryzen 7 2700x supports 2933MHz according to it's website but I read a lot of people saying 3200MHz RAM is the best for performance with these processors.
1. Are people using 3200 RAM basically overclocking?
2. Does XMP negatively affect your processor?
3. Most motherboards like MSI B450 Tomahawk seem to be OC'ing RAM above 2667 MHz so basically using XMP profiles for 2800 MHz and above however some Gigabyte boards like Gigabyte B450 AOROUS M seem to be OC'ing only at 3200 MHz and above. What's up with that? Were most people supposed to be only using 2667 MHz RAM and is everyone else overclocking and why don't these boards support up to 2933 without OC since the processor supports 2933?
4. Finally is it even worth it to get into 3200 MHz or should I just get the Gigabyte board with 3000 MHz RAM for optimal use with the Ryzen 7 2700x that seems to support up to 2933 MHz anyway?
