So after a long while of getting build help, and waiting for parts to come in, I got my computer physically put together. I ran into a problem when I went to plug it in. The computer would repeatedly shut down and restart, never loading up the BIOS page at all (no display). So I read into some things to begin troubleshooting and finding the problem. Basically I removed the graphics card and one of the sticks of ram. After that the computer booted up like it was supposed to. Then I decided to take that RAM stick out and replace it with the one I had taken out earlier. The computer started to restart again with the same issue as before. So I put everything back together without the second RAM stick and got Windows installed. Everything seems to be working now.
My question is about replacing the faulty RAM stick (assuming its faulty anyways). I ordered from Newegg and to be honest their return/replace policy is not really great in my opinion. It will take weeks to get replacements and I will have to return both sticks, making the computer not usable. What I was hoping to be able to do is just buy one more 4GB ram stick and slap it in there. I have read somewhere that doing this may cause compatibility issues though. This is my build. Can I get some suggestions please?
http://pcpartpicker.com/p/yHCTRB
