Ram timings and speed
John Preston
13
Hello,
My Ram defaults to
9 9 9 24, but it says on the stick that is should be 10 10 10 27 and it has also gone up to 11 11 11 29.
Which one is the best option.
I have 32gb corsair vengeance dual channel ram.
Go into BIOS and enable XMP, select profile 1 - should set them to 1600, 10-10-10-27 for you, if any problems can make sure you have the latest BIOS or let me know the mobo model, might need manual setup
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 8192 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number CML32GX3M4A1600C10
Manufacturing date Week 13/Year 12
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.3
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-22 @ 457 MHz
JEDEC #2 7.0-7-7-20-26 @ 533 MHz
JEDEC #3 9.0-9-9-24-33 @ 666 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.500 Volts
Min Cycle time 1.250 ns (800 MHz)
Max CL 10.0
Min tRP 12.50 ns
Min tRCD 12.50 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 50.63 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-7-7-17-25-2T @ 480 MHz (1.500 Volts)
XMP #2 10.0-10-10-27-41-2T @ 800 MHz (1.500 Volts)
DIMM # 2
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Size 8192 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.3
AMP no
Max CL 10.0
Min tRP 12.50 ns
Min tRCD 12.50 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 50.63 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 3
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 8192 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.3
AMP no
Max CL 10.0
Min tRP 12.50 ns
Min tRCD 12.50 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 50.63 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 4
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 8192 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.3
AMP no
Max CL 10.0
Min tRP 12.50 ns
Min tRCD 12.50 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 50.63 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
Chipset
Northbridge Intel Haswell rev. 06
Southbridge Intel Z87 rev. C1
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 32 GBytes
and its I7 4770k
