ram usage climbs to max during and after downloads
russ1000
13
I have a fairly new build using I7 4790k, z97 motherboard, 2 8gb sticks of gskill trident 2400 cas 10 ram. Window 8.1 64 bit. My issue is when i download my memory usage climbs a bit which is normal but once download is finished the mem usage keeps climbing to like 90%. I have look through task manager and nothing is using too much ram, I have ran a couple of malware scans, ran memtest. If i restart pc it goes back to normal until i download something. I use a kingston 120 ssd and 1 tb wd black.
It happens with mostly steam games, and torrents (movies)
Well downloading big files like games or Movies (1GB or above in general) can use RAM. But I've never heard downloading anything making RAM get even close to 90% when you have 8GB or above, let alone 16GB.
Maybe its your HDD. if possible, add another HDD and test it for RAM usage while downloading.
it doesnt really get high until after download has finished but I will pick up a new 1tb seagate they are on sale for 54.99
Yeah disabling those didnt help i ran two download s in a row (games) when they finished it was at 80% i have ordered a new hdd and 2more sticks (i needed 2 for another build anyway)
an update changed ram and hdd. Still no luck but i installed 2x4gb sticks of team dark and it runs up to the same 90% mark, it did with the 16gb. Next is re install windows and if that dont work maybe mem controller / motherboard?
i have reset bios and cleared cmos, thanks still no luck i have changed memory settings reset default settings. I am curious about this intel smart software or marvel ( i am not using the marvel sata connectors on the board)
well i finally figured it out the PEJUman was on the right track it was " HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Ndu "
Change the start value to "4" (Disable) and restart your PC
thanks for all your answers
