Hello everyone!
It's another tutorial on RAM! With my last one just having crested 11,000 reads I figured I would write another, this one slightly more detailed. Rather than focusing on the exact amount of RAM you should have, this tutorial will go over the following: RAM speed (CAS Latency & Mhz), overclocking and cooling. A mix of both personal experience and factual knowledge, I will focus on bringing everything to the table I can. If you have feedback, PM me.
There are two primary methods of measuring RAM speed. The first and most common is megahertz, usually expressed like "1600Mhz". The other way of writing this would be "PC3 12800". Megahertz is the speed at which the RAM operates. As a general rule, the faster the RAM operates, the snappier you're system will be. I run 16GB of 1600Mhz and find it 100% sufficient for streaming to twitch while playing any game.
The second method of measuring relative RAM speed is CAS Latency. CAS stands for Column Address Strobe. If you Google CAS Latency, you get a load of technical jargon with a side of understandable information. Because I would hate for you to be confused, I'll sum it up. CAS Latency is the measured delay between the moment the memory controller queries or asks the RAM for information, and the time at which it becomes available. The smaller the CAS number is, the faster the RAM can provide data to the memory controller. Unless you use FBDIMM (fully buffered memory), you're memory controller is located on the CPU die. If you know what none of this means, then this tutorial should not be you're choice reading material......yet!
As soon as I mentioned overclocking, some of you probably started drooling. Yes yes, you can overclock RAM. However, it is a complicated process and can have considerable repercussions. If you're RAM is crap, overclocking could lead to premature failure. An bad overclock can destabilize a system and make it unable to boot. DDR3 has a stock voltage of 1.5, and the JEDEC recommended max is 1.575. Supposedly a module can handle 1.975 volts without permanent damage, but it is not guaranteed to function at this level. That said, don't live in fear. Play around with RAM speeds in the BIOS, and if you have them, ask questions in the forum.
As a general rule, RAM cooling is over advertised. I personally recommend that you ignore Nike on this one and don't believe the hype. However, if you're into it, there are ways to cool RAM. The cheapest by far is a set of heat spreaders. Probably the only method I would recommend for the causal user, spreaders are quite helpful if you're case has decent airflow. If you have FBDIMM RAM, you should DEFINATELY have spreaders. The best ones have fins, like these:
If you have a preexisting water cooling loop, or are adding one, you can water cool RAM with a relatively simple water block. But, if you're loop comes out over budget, this is the first thing I would cut out. Its pretty unnecessary unless you plan on overclocking you're RAM.
The middle ground between heat spreaders and water blocks is a simple fan assembly. If used in conjunction with a set of spreaders, it should provide more than adequate cooling!
Thanks for reading, advice and or questions are always welcome!
