Question Random audio glitching thru pc audio
Dec 22, 2019
5
First off, thanks to anyone that can shed some light on this for me.
I am experiencing a strange audio issue that happens either thru my headphones or pc speakers. I can be watching videos on youtube, movies on netflix and even gaming and I get this almost like a electrical glitch sound coming thru my speakers or headphones randomly. I could be playing for hours before it happens or five minutes. I have recently installed a new motherboard, cpu and memory...before that the audio was fine.
Things that I have tried so far:
  • re installed windows 10
  • Uninstalled audio drivers and re installed them (Realtek)
  • Enabled and disabled both microsoft and realtek audio to see if one would work...both had the same results.
  • Used the graphic card's audio thru my HDMI cable to my monitor - tried both headphones and pc speakers...same results.
  • Tested both audio using my Display / HDMI cable...same results.
  • Updated Bios / Chipset
  • Removed the motherboard to check for ground issues.
  • Removed memory sticks and reinstalled....wanted to make sure they where seated good.
  • Tested audio with my headphones with the pc speakers unplugged from pc.
I am going crazy over this...I don't know if it's a grounding issue causing this or what. Any insight would be great 😕
PC Specs:
Overview
Machine Custom Computer
Operating System Microsoft Windows 10 Home (64-bit)
Memory 16 GB
Processor AMD Ryzen 5 3600 6-Core Processor
Motherboard ASUSTeK COMPUTER INC. - ROG STRIX B450-F GAMING
Video Cards NVIDIA GeForce GTX 1080 Ti
Monitors DELL S3220DG
Hard Disk Generic Flash Disk USB Device (16.0 GB)
Network Card Intel(R) Gigabit CT Desktop Adapter
CPU
Processor
Name AMD Ryzen 5
Code Name Matisse
TDP --
Package --
Technology 7 nm
Core Voltage 1.44 V
Specification AMD Ryzen 5 3600 6-Core Processor
Family 15
Model --
Stepping --
Ext. Family --
Ext. Model --
Revision --
Instructions MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, NX, VMX, AES, AVX, AVX2, FMA3
Clocks
Core Speed 4099 MHz
Multiplier x 41
Bus Speed 100 MHz
QPILink --
Cache
L1 Data 6 x 32 KBytes
L1 Inst 6 x 32 KBytes
Level 2 6 x 512 KBytes
Level3 2 x 16384 KBytes
Motherboard
Motherboard
Manufacturer ASUSTeK COMPUTER INC.
Model ROG STRIX B450-F GAMING Rev 1.xx
Chipset AMD Ryzen SOC
Revision 00
Southbrige AMD B450
Revision 51
LPCIO --
BIOS
Core Speed American Megatrends Inc.
Version 2901
Date 10/16/2019
Graphic Interface
Version --
Transfer Rate --
Max. Supported --
Memory
General
Type DDR4
Size 16384 MBytes
Channel# --
DC Model --
NB Frequency --
Timings
DRAM Frequency 1599.6 MHz
FSB😀RAM --
CAS# Latency(CL) 16 clocks
RAS# to CAS# Delay(tRCD) 18 clocks
RAS# Precharge(tRP) 18 clocks
Cycle Time(rRAS) 36 clocks
Bank Cycle Time(tRC) --
Command Rate(CR) 1 clocks
Graphics
GPU
Name NVIDIA GeForce GTX 1080 Ti
Code Name GP102
Technology 16 nm
Revision --
Clocks
Core 1556.5 MHz
Shader --
Memory 5508 MHz
Memory
Size 11264 MBytes
Type 10
Bus Width -
