Ok, So. I have just had this pc built.
Phenom II x4 Black Edition 3.4ghz
Asrock 970 Extreme 4
Sapphire Radeon HD 7850 2GB OC Edition
8GB Ram
Windows 7 64bit
The problem i am having is in some games. For instance War z and Fallout new vegas.
I will play, then the game freezes for a SPLIT second, not even a second, the VERY QUICK freeze causes my fps to drop buy about 20-30 frames then jumps back up to the 60 frames i usually get.
My temps are fine.
CPU : 20-25c when idle and 40-45c underload
GPU - 25c idle and 48 max underload.
As you can see...nothing seems wrong. Does anyone have some sort of explanation of this whatsoever?
8GB Ram
Windows 7 64bit
My temps are fine.
