Random freeze and sound stutter
RALDR
Commendable
Mar 17, 2016
.For many months i have been facing an issue with freezes and sound stuttering. It seems to only happen when the gpu utilization and power spikes to 100
Specs
Os windows 7 ultimate 64 bit
Gpu gtx 690
Cpu intel core i7 4770
700 watt power supply
8gb ram
Motherboard gigabyte h 110
Hi there RALDR,
What are you doing when these spikes occur? Are you playing games or just browsing?
Several things you can try:
- Update your GPU drivers.
- Measure your system's temps.
- Try to take your GPU out and see if the issue persists.(you have integrated one)
- Run some stress testing.
- The last thing you can try is to troubleshoot your PSU. Unfortunately, the easiest way to do so is to borrow a PSU from somebody and see if the issue persists.
Hope any of these helps,
D_Know_WD
Hi there RALDR,
D_Know_WD
