I've been experiencing issue with my build for probably over a year now. My current specs are
Motherboard: Asus Prime B360M-A
CPU: Intel I7 8700k 3.20ghz
CPU Cooling: Cooler Master Hyper 212 Evo
RAM: 2x8gb Vulcan DDR4 2666 15-17-17-35
GPU: EVGA GeForce GTX 1660 TI SC Ultra Gaming 6GB GDDR6
PSU: EVGA 700 GD 100-GD-0700-V1 700W ATX12V / EPS12V 80 PLUS GOLD
I was given this PC and changed all the parts out except for the motherboard and CPU trying to solve this issue. It originally had a 400W unknown brand PSU, MSI Armor RX580 4gb, 1x8gb Vulcan DDR4 2400 14-16-16-31 and a stock intel CPU cooler. I upgraded the one stick of ram into the two I have now to use the dual channel memory before the crashing started. Upon my first few hard crashes/reboots I looked into the prebuilt I was given and saw that the PSU wasn't enough to power the system and it was the most common solution to random crashes. After I changed the PSU, the crashes/reboots seemed to happen less but still happened nonetheless, so my next step was to look into overheating. I started with replacing the thermal paste on the CPU and on the GPU die and installing the Cooler Master onto the CPU, while this did help with my temps(Moving my CPU from 60c average to 45c and the GPU from 60c to 50c) the crashes still persisted.
However I did get one BSOD at some point that gave me the error code IRQL_NOT_LESS_OR_EQUAL ntoskrnl.exe, this is the only BSOD and .dmp file I've managed to get.
During my many trials and tribulations I've ended up:
Clean Install of windows
Bios Update
Bios CMOS Reset
Video, Audio, and Software driver uninstall and reinstall
SFC commands in command prompt
DDU driver wipes
Memtest86
Windows Memory Diagnostic Tool
and probably others I cannot remember right now.
At this point I'm not sure what's wrong. I thought maybe my cpu is unstable since it's running at stock core voltage (at 1.040v) but I didn't want to mess with any of that since I'm not too knowledgeable. Maybe my CPU or Motherboard are bad? My PC still POSTs and the hard crashes/reboots are completely random. Sometimes it's during google chrome, others it's during Warzone, Battlefront 2 or even Old School Runescape! Any help would be greatly appreciated!
Bios Update
Bios CMOS Reset
DDU driver wipes
Memtest86
