Hello!
I have just recently realized through msi afterburner and realtemp that my cpu temps go crazy even though i have nothing running and its on idle. The temps are fine for the inital startup, around 27-30 when i start the pc for the mobo, after around 5 mins then the mobo temp goes straight to 40 degrees and lingers there when it should be still at 30. cpu is the same and initially lingers around 25-32 degrees, after 5 mins it shoots up to around 40 then back down to 30 and keeps going up and down no matter what process i close! Playing games is fine and nothing goes crazy high, cpu at about 45 degrees during heaven benchmark and using 30-40 percent. gpu 65 degrees. Here is a pic. http://imgur.com/gallery/zZVt0
My Rig:
Intel i7-4790k 4ghz
GTX 980ti
Msi gaming 5 mobo z97
Much appreciate the help
My Rig:
Intel i7-4790k 4ghz
GTX 980ti
