So I join this helpful forum for advice and wish you a warm hello.
I hope this is the correct Sub-category for the issue. I apologize before-hand if it is not.
Onto my issue
I've been having some PC issues fairly recently and I was unable to find anything relevant to my situation unfortunately.
It happens on only two games so far (Skyrim and AC Brotherhood). During the middle of gaming, the monitor suddenly stops receiving a signal and the sound also disappears. Pressing the reset or power button of the PC case does not work, so I have to cut the power through the PSU and turn the PC back on.
Strangely, AC Revelation had no issues whatsoever and the graphic settings were much higher than in AC Brotherhood. In AC Brotherhood, the issue only occurs in cut-scenes. Graphic Settings apparently do not influence the frequency of the issue.
The second problem when turning on the PC, the monitor sometimes doesn't receive a signal either. Furthermore, the PC cannot be shutdown or reset through the case Power button. Only through shutting down the power with the PSU again. Another observation I made was that the Keyboard lights for Numlock, Capslock etc. do not flash when the 'no signal' error occurs. When they flash, it is an indication that the signal is working and the PC will run fine. The flash occurs 2-3 seconds before the PC properly starts up and the monitor is able to receive the video signal. If there is no light flash, the PC will have to be shutdown and restarted until the signal is regained.
These symptoms have been occurring quite randomly but only consistently occur to the above two games so far.
Now to the PC specs.
CPU: AMD Phenom II X3 720 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103649
MB: Asus M4A78T-E http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366
GPU: EVGA GTX 560 SuperClocked (Exact product is not available in Newegg)
RAM: G.Skill 4Gb (2 x 2) Model F3-10666CL8D-4GBHK http://www.newegg.com/Product/Product.aspx?Item=N82E16820231189&name=Desktop-Memory
PSU: OCZ StealthXTreme II 700w http://www.newegg.com/Product/Product.aspx?Item=N82E16817341040
HDD: 1TB WD1002FAEX Black http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Notes
Temperatures are all decent levels: 25-45 Celsius
PC interior is fairly clean from any dust.
No Ram issues.
There is no built in MB speaker for the error beeps.
No Viruses or Malware, I made several scans with different software.
Hard drive is functioning well, used the WD Data Lifeguard software to check for any errors and de-fragmentation is done every month.
So far I've been only able to pinpoint the problem to three components to either:
The Motherboard is failing
The GPU is failing
The PSU is insufficient/failing (my primary suspicion)
All components (except the GPU) are three years of age and the GPU is one year old. 'No signal' issues had only occurred until recently (about a month).
Advice
If the PSU is the issue, as I suspect, I'd like some recommendations. I'm currently choosing between the Corsair 650TXV2 and the XFX PRO650W.
Feedback is appreciated, I hope the info is sufficient and thank you for your time.
Cheers
Yanoda
Onto my issue
Notes
No Ram issues.
The GPU is failing
Advice
Cheers
Yanoda
