Hi.
I built a PC for my son 1yr5mths ago that developed a problem that I fixed 12 months ago by replacing the processor. Recently it developed another problem.
When starting, it would boot up but FAIL to POST and go into continues restarts with/without the BIOS beep noise, and I can’t go into BIOS. If I switch it off for longer it would start up, fail to POST and just stay on without loading BIOS or Windows. I will also hear a repetitive clicking noise every 2-3 seconds. If I remove one of the RAM modules and then start the computer, it works fine. It will also start when I put back the RAM module. I can run PRIME95 with no problems and it work for hrs. Plus if I restart the computer it works. BUT, if I switch the computer for hrs or a day, the symptoms come back, which I can fix again by removing the RAM and putting it back in.
The components are all new apart from the RAM (Corsair CMZ8GX3M2A1600C9B that came from my 16gb PC) and the 2nd hard drive. Could this be a RAM problem?
I’ve just ordered new Corsair CMZ8GX3M2A1600C9 RAM (they are compatible according to Gigabyte)
Components
Motherboard- Gigagabyte Z97X- gaming 3
PCU- Intel Pentium G3258
RAM - Corsair CMZ8GX3M2A1600C9B (two sticks 4gb)
PSU- Corsair Builder Series CXM 600W Modular 80 PLUS Bronze Certified ATX/EPS PS
Primary HD - Crucial CT256MX100SSD1 256GB MX100 SATA
Scondery HD –Samsung 2tb
Components
