Question Random Reboots, Need help determining the cause please!
Jan 17, 2021
8
I am getting the occasional random restart, happens sometimes when im just watching twitch streams but mostly its random.
Here is the event log info. If any other info is needed just lmk whats needed. Also should i just consider doing a system restore?
Log Name: System
Source: EventLog
Date: 1/17/2021 4:53:33 PM
Event ID: 6008
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP-ON92A05
Description:
The previous system shutdown at 4:49:32 PM on ‎1/‎17/‎2021 was unexpected.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2021-01-17T21:53:33.8731080Z" />
<EventRecordID>14866</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>System</Channel>
<Computer>DESKTOP-ON92A05</Computer>
<Security />
</System>
<EventData>
<Data>4:49:32 PM</Data>
<Data>‎1/‎17/‎2021</Data>
<Data>
</Data>
<Data>
</Data>
<Data>342034</Data>
<Data>
</Data>
<Data>
</Data>
<Binary>E5070100000011001000310020007503E5070100000011001500310020007503600900003C000000010000006009000001000000B004000001000000F9FFFFFF</Binary>
</EventData>
</Event>
OS Name Microsoft Windows 10 Pro
Version 10.0.19042 Build 19042
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-ON92A05
System Manufacturer Gigabyte Technology Co., Ltd.
System Model X570 AORUS ELITE WIFI
System Type x64-based PC
System SKU Default string
Processor AMD Ryzen 7 2700X Eight-Core Processor, 3693 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. F31d, 10/26/2020
SMBIOS Version 3.3
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Gigabyte Technology Co., Ltd.
BaseBoard Product X570 AORUS ELITE WIFI
BaseBoard Version x.x
Platform Role Desktop
Secure Boot State Off
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "10.0.19041.488"
User Name DESKTOP-ON92A05\effri
Time Zone Eastern Standard Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 26.0 GB
Total Virtual Memory 36.7 GB
Available Virtual Memory 27.5 GB
Page File Space 4.75 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not Modern Standby, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
PSU-
Apevia ATX-SN1050W Signature 1050W 80+ Bronze Certified Active PFC ATX Modular Gaming Power Supply
GPU- MSI GTX 1660 SUPER
MEMORY-
Silicon Power XPOWER Turbine Gaming DDR4 16GB (8GBx2) 3200MHz (PC4 25600) 288-pin C16 1.35V UDIMM Desktop Memory Module - Low Voltage (SP016GXLZU320BDA)
BOOT DRIVE-
XPG SX8200 Pro 512GB 3D NAND NVMe Gen3x4 PCIe M.2 2280 Solid State Drive R/W up to 3350/2350MB/s SSD (ASX8200PNP-512GT-C)
I had the CPU overclocked all cores @ 4.075 Ghz, but i have since lowered it to 4 Ghz all cores, Temp goes no higher than 52 degrees C. under stress test.
The Memory is running at 2933 Mhz XMP profile activated.
I cant think of anything else that would be relevant.
