Random Restarts Help Extremely Detailed Specs
Craig Eutsler
7
Built this PC about 3 years ago.
Have been having trouble with random restarts. Have built PCs in the past nothing wrong with them, but this one has been giving me trouble. Fully detailed specs below. Apologies for the long list of information and formats. This was all copy pasted from the vendors i got the parts from. Sorry don't know how to hide part of a post behind a drop slide.
Mother Board
Brand
GIGABYTE
Model
GA-Z77M-D3H-MVP
CPU Socket Type
LGA 1155
CPU Type
Core i7 / i5 / i3 (LGA1155)
Chipset
Intel Z77
Number of Memory Slots
4×240pin
Memory Standard
DDR3 2400(OC)/1600/1333/1066
Maximum Memory Supported
32GB
Channel Supported
Dual Channel
Expansion Slots
1 x PCI Express 3.0 x16
1 x PCI Express 2.0 x16 @x4
1 x PCI Express x1
1 x PCI Slot
Storage Devices
4 x SATA 3Gb/s
2 x SATA 6Gb/s
SATA RAID 0/1/5/10
Onboard Video Chipset
Supported only by CPU with integrated graphic
Audio Chipset
VIA VT2021
Audio Channels
8 Channels
Onboard LAN
Max LAN Speed
10/100/1000Mbps
Rear Panel Ports
1 x PS/2 keyboard/mouse port
Video Ports
D-Sub + DVI
1 x HDMI
2 x USB 3.0
4 x USB 2.0
Audio Ports
3 Ports
Internal I/O Connectors
Onboard USB
2 x USB 3.0 + 6 x USB 2.0
Other Connectors
1 x 24-pin ATX main power connector
1 x 4-pin ATX 12V power connector
1 x CPU fan header
2 x system fan headers
1 x front panel header
1 x front panel audio header
1 x S/PDIF Out header
1 x serial port header
1 x parallel port
1 x Trusted Platform Module (TPM) header
1 x Clear CMOS jumper
Physical Spec
Form Factor
Micro ATX
Dimensions (W x L)
9.6" x 8.66"
Power Pin
24 Pin
Features
GIGABYTE 3D BIOS
GIGABYTE Ultra Durable 4 Classic
Lucid Universal MVP Support
3rd Generation Intel Core processors
Designed for PCI Express Gen.3 Support
Intel Rapid Start Technology
Intel Smart Connect Technology
GIGABYTE EZ Smart Response
GIGABYTE EZ Setup
GIGABYTE 333 Onboard Acceleration
GIGABYTE On/Off Charge
Enhanced Built-in Visuals
Intel Quick Sync 2.0
CPU
Intel Series Core i5
Name Core i5-3350P
Model BX80637i53350P
CPU Socket Type
LGA 1155
Core Name
Ivy Bridge
# of Cores
Quad-Core
Operating Frequency
3.1GHz (3.3GHz Turbo)
L3 Cache
6MB
Manufacturing Tech
22nm
64-Bit Support
Yes
Hyper-Threading Support
No
Integrated Memory Controller Speed
Supports Dual-channel DDR3-1333/1600
Virtualization Technology Support
Yes
Multimedia Instruction
SSE4.1/4.2, AVX
Thermal Design Power
69W
Cooling Device
Heatsink and fan included
Ram
Brand
HyperX
Series
Beast
Model
KHX24C11T3K2/8X
Details
Capacity
8GB (2 x 4GB)
Type
240-Pin DDR3 SDRAM
Speed
DDR3 2400 (PC3 19200)
Cas Latency
11
Voltage
1.65V
ECC
No
Buffered/Registered
Unbuffered
Multi-channel Kit
Dual Channel Kit
Heat Spreader
Yes
Features
A new heatspreader to maximize thermal dissipation and provide increased reliability. This heatspreader also features a new color and design to add to the character of the memory. The HyperX Beast is part of the Predator family, which is Kingston's premiere memory line.
The HyperX Beast is compatible with third-generation Intel Core i5 and i7 processors and the latest AMD performance and gaming processors. The memory is Intel XMP ready, giving you higher-performing frequencies, timings, and voltages in a few clicks.
GPU
GTX 970 Engine Specs:
1664CUDA Cores
1050Base Clock (MHz)
1178Boost Clock (MHz)
109Texture Fill Rate (GigaTexels/sec)
GTX 970 Memory Specs:
7.0 GbpsMemory Clock
4 GBStandard Memory Config
GDDR5Memory Interface
256-bitMemory Interface Width
224Memory Bandwidth (GB/sec)
GTX 970 Technology Support:
Yes (4-way)NVIDIA SLI® Ready
YesNVIDIA G-Sync™-Ready
YesNVIDIA GameStream™-Ready
YesGeForce ShadowPlay™
2.0NVIDIA GPU Boost™
YesDynamic Super Resolution
YesMFAA
YesNVIDIA GameWorks™
12 API with Feature Level 12_1Microsoft DirectX
4.4OpenGL
YesCUDA
PCI Express 3.0 Bus Support
Windows 8 & 8.1, Windows 7, Windows Vista, Linux, FreeBSD x86OS Certification
Display Support:
5120x3200Maximum Digital Resolution*
2048x1536Maximum VGA Resolution
Dual Link DVI-I, HDMI 2.0, 3x DisplayPort 1.2 Standard Display Connectors
4 displaysMulti Monitor
YesHDCP
InternalAudio Input for HDMI
GTX 970 Graphics Card Dimensions:
4.376 inchesHeight
10.5 inchesLength
Dual-widthWidth
Thermal and Power Specs:
98 CMaximum GPU Temperature (in C)
145 WGraphics Card Power (W)
500 WRecommended System Power (W)**
2x 6-pinsSupplementary Power Connectors
PSU
Brand
CORSAIR
Model
TX750M
Series
Enthusiast Series
Details
Type
ATX12V v2.31 / EPS12V v2.92
Maximum Power
750W
Fans
1 x double ball-bearing
Main Connector
24Pin
+12V Rails
Single
PCI-Express Connector
4 x 6+2-Pin
SATA Power Connector
8
Haswell Support
Certified
Modular
Semi Modular
Efficiency
up to 85%
Energy-Efficient
80 PLUS BRONZE Certified
Over Voltage Protection
Yes
Input Voltage
90 - 264 V
Output
+3.3V@30A, +5V@30A, +12V@62A, -12V@0.8A, +5VSB@3A
MTBF
>100,000 Hours
Approvals
UL, CUL, CE, CB, FCC Class B, TUV, CCC, RCM
Dimensions
5.9"(W) x 3.4"(H) x 6.3"(L)
Weight
6.04 lbs
Features
Connectors
1 x Main connector (24Pin)
2 x 4+4-Pin 12V CPU
6 x Peripheral
8 x SATA
2 x Floppy
4 x PCI-E
Features
The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
An ultra-quiet double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature.
80PLUS Bronze certified, delivering up to 85% energy efficiency at real world load conditions.
Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
A dedicated single +12V rail offers maximum compatibility with the latest components.
Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
SSD (OS Drive)
Brand
OCZ
Series
Vertex 2
Model
OCZ-vertex2 ata
Max Read¹ up to 285 MB/s
Max Write¹ up to 275 MB/s
Sustained Write² up to 250 MB/s
4KB Random Write³ 50,000 IOPS
Seek Time 0.1 ms
P H Y S I C A L
Capacities 90GB
NAND Components Multi-Level Cell (MLC)
Interface SATA II / 3Gbps
Form Factor 3.5 Inch
Controller SandForce 1222
Dimensions (L x W x H) 146 x 101.6 x 11 mm
Weight 135g (may vary slightly depending on capacity)
E N V I R O N M E N T A L
Power Consumption Idle: 0.5 Watts Active: 2 Watts
Operating Temperature 0°C ~ +70°C
Storage Temperature -45°C ~ +85°C
Shock Resistance 1500G
Certifications RoHS, CE, FCC
R E L I A B I L I T Y
MTBF 2 million hours
ECC Recovery Up to 24 bytes correctable per 512-byte sector
Product Health Monitoring Self-Monitoring, Analysis and Reporting Technology (SMART)
C O M P A T I B I L I T Y
Serial ATA (SATA) Fully compliant with Serial ATA International Organization: Serial ATA Revision 2.6. Fully compliant with
ATA/ATAPI-7 Standard Native Command Queuing (NCQ)
Operating System Windows XP 32-Bit and 64-Bit; Windows Vista 32-Bit & 64 Bit; Windows 7 32-Bit and 64-Bit;
Linux
Power Requirements Standard SATA Power Connector
HDD (Temp Files being written to)
Brand
Western Digital
Series
Black
Model
WD1002FAEX
Packaging
Bare Drive
Performance
Interface
SATA 6.0Gb/s
Capacity
1TB
RPM
7200 RPM
Cache
64MB
Features
Usage
For Power Computing
Dimensions
Form Factor
3.5"
Optical Drive
Brand
ASUS
Model
DRW-24B1ST/BLK/B/AS
Type
DVD Burner
Performance
DVD-ROM Access Time
150ms
CD-ROM Access Time
130ms
Write Speed
DVD+R
24X
DVD+RW
8X
DVD-R
24X
DVD-RW
6X
CD-R
48X
CD-RW
24X
DVD+R DL
8X
DVD-R DL
8X
DVD-RAM
5X
Read Speed
DVD-ROM
16X
CD-ROM
48X
Details
Panel Color
Black
Configuration
Load Type
Tray
Interface
SATA
Software
Operating Systems Supported
Windows 8
Windows 7
Windows Vista
Windows XP
Software Contents
Power2Go 8(optional)
E-Green
Features
Features
The ASUS DRW-24B1LT / 24B1ST is capable of reading and writing data on DVD + / - R,DVD + / - RW, DVDRAM formats. It is a power saving drive and allows you to permanently delete the data on rewritable discs. This provides you with flexibility and efficiency in terms of multimedia data storage and sharing
System Requirements
CPU: Intel Pentium 300 MHz or higher
RAM: 128 MB or more is recommended
HDD: 10GB or more
Packaging
Package Types
Bare Drive
Before Load
After Load
Added screen caps of temps
Your temps seem okay, that makes me thing something is wrong with the power delivery, what do the windows logs say about the crashes?
https://www.dropbox.com/s/3n0f2qi6651w6nu/windows%20log.evtx?dl=0
Sorry, but drop box seemed like the simplest way to show my windows log since copy past would be a giant wall of text.
Unfortunately I can't seem to open the file, it just freezes.
