Random restarts no warning no BSOD on newly built PC HELP!!!
bintangsbgj
My newly built PC starting to do random restarts! There are no warning no BSOD or whatsoever!! It is so confusing!
Several things I've tried:
  • Clean reinstall Windows
    Checking all drivers, everything seems fine
    Checked CPU temperature, ~30 degree Celsius when idling
Here's my specs:
  • AMD A8-9600 3.1 GHz APU
    MSi B350M Gaming Pro Motherboard
    G.Skill NT Series 4GB 2400MHz DDR4 RAM
    Corsair VS450 450W PSU
I haven't installed any dedicated GPU card.
The restart occurs randomly but it never occur when I'm gaming. As far as I remember it happens several times when I was using Chrome. Any help would be appreciated!
Paul Wilson
57
12
windows van be confugured to never show a BSOD
It sounds like a bad ram module to me (or if you`re very unlucky a problem with the ram slot on the mobo)
using a different computer make a booteble medium with: https://www.memtest86.com/
Run it for a couple of hours, atleast you`ll know if the RAM is working normaly
next you could check your harddrive, but since you didn`t include a brand for that, i can`t recomend the right tool for that
